I'm guessing you are drawing to much current off of output 2 with both sirens activated. A quick test would be to just run one at a time and see if the sound changes.Guy669 said:I have two sirens. One in my attic and one in my basement. The siren comes from my previous alarm system. They are connected to output 2. The siren is a DSC, SD 20watts, two tone siren, 12 VDC, 20W max.
Any idea what can be causing this?
Ah, yea, good point.Work2Play said:Well I think he had the wrong output type as well - speaker instead of voltage.
I somehow missed that, where is it listed (the 7000 mA draw)?DELInstallations said:BSR,
The sirens draw 7000 mA each, so he's capped at 1.4A total load on the output when set for voltage, not over 1.6 A.
