The first thing to ask yourself is "has anything changed recently?" Did you add some new electronic equipment, or even old equipment that wasn't previously plugged in? Did you install some new LED light bulbs? Start going around and disconnecting things, or flipping circuit breakers and see if the problem goes away. That will help you narrow down what might be causing the problem.
