This is my first post so I am hopping this is in the right form. I have a fireplace in the master bedroom that's I have my Elk M1 turn on and off though a relay, their is also a keypad with a built in temperature sensor located in the room as well.  I would like to have it be on a thermostat but i don't really want to pay for a thermostat. So I was hoping to create some rules on the Elk like "Thermostat1 is in auto heat, and key pad temp is less desired temp, then turn on output 10" My goal is to just use the web interface to set the temperatures for the thermostat. But before I tried this, I wanted to check and see if this is possible, the main problem I can think of is if the elk wont enable the thermostat with out one plugged in? I don't have the ELK-M1XEP yet, so i also haven't been able to test this. Hopefully that all made sense.
Dewy
Dewy
