mikejrc
Here are my findings about cellular communications using Uplink, Alarm Relay and your M1 Gold:
- The Uplink 2500 is a cellular GSM communicator that connects to your M1 control panel using a serial expander XSP, there is a cable made by elk that goes from the DB9 port to a molex plug on the Uplink radio. The XSP has a special firmware for the Uplink as well.
- Full reporting capability is enabled, direct communication without the use of dial capture. The only other communicator not dial capture based is the AES Intellinet, (radio not cellular) which also connects to an XSP with a special firmware. Any other communicator out there will use dial capture and will fake a dial tone making the control panel believe is talking to a central station receiver.
- This Uplink 2500 is also one of the few you can buy directly without being tied to a specific service, dealer or central station. It has also a reasonable cost.
- The signal path will be: from M1 control panel, to XSP module via serial, to Uplink 2500, to Uplink's operation center, to alarm central station or directly to you via SMS. If using a central station you could receive text or email if the central station software allows it.
- To receive SMS without a central station but directly from Uplink, a dealer must set it up or allow it. Some dealers specially central stations will not allow this because they want to charge you their standard monitoring fee plus the Uplink service fee.
- I contacted Alarm Relay and they provide monitoring via Uplink, but they were not aware of the full reporting capabilities when connected to an ELK M1, and were not aware of Uplink's capability to send you SMS directly. Alarm Relay then contacted Uplink and verified that the ELK M1 and Uplink does support full reporting and that Uplink can send you SMS directly if Alarm Relay allows it.
- Alarm Relay will not sell the Uplink 2500, you can buy it online then call them to activate it. They will allow SMS to be sent directly to you, but signals will still be sent from Uplink to Alarm Relay. They will charge instead of $8.99 for dial up monitoring, $20.99 for Uplink service, far lower than any other radio or cell service (average $50). No limit on how many signals your M1 sends, since the Uplink service covers the cost of the cell communication.
- When calling Alarm Relay you can talk to Camber at extension 118, she has all the details and she was the one that called me back with their findings after Alarm Relay contacted Uplink. I told her that other M1 owners may follow and call her for details on this.
- I talked to Uplink sales 1800 number and they also confirmed that the 2500 is the unit listed to work with the M1 for full reporting and that SMS could be sent directly to a cell phone when they receive the alarm reporting codes, but Uplink will not activate this or activate service directly with end users only via dealers or central stations.
I hope this info helps, I encourage others to look further into this.
It's a great opportunity to have a well priced full reporting GSM based service without paying so much to those greedy central stations with their multi year contracts.
I will be posting in the future my experiences with this service once I activate it, if anyone does it sooner please let us know your experience.
