Mp333
I already have the ELK-M1DBH. I realize the M1DBHR would be ideal but...
My m1g is setup with just two keypads wired in to the RS485 on M1G screw terminal, I am looking to add M1XSP and M1DBH. Will probably add another M1XSP down the road. Can I use M1DBBH n my setup with bare wires for the keypad at the moment? They will be terminated with RJ45.It is a 6 wire home run to the keypad.
donot want to use all the six conductors. Since I was planning to use the spare two wires of the keypad home run for speaker. The first two keypads gets plugged into J1 & J2 with pos & neg power and A & B databus. For the return of the second keypad can I jump the databus A & B from screw terminal on M1DBH and wire them parallel into J1 & J2 RJ45? The M1XSP would be connected to J3 and J4 would have the terminating plug.
