ELK M1G - Out of Service Sensor
What is the best way with Elk-M1G to put a sensor out of service while it is being repaired or test so you can eliminate bypassing when the system is armed?
Thanks, Paul
That is a good way to go, unless you have multiple contacts on a single zone, which would be best served by jumping out the affected unit.
Thanks for the follow-up.
It is a single sensor and I like the Diabled option, found in Zone > Configuration > Definition.
I was looking to do it in the wireless setup area not thinking about the other options.
Regards, paul
