Hello I was wondering if anyone has experienced the following behavior before when running multiple M1XSP:
Setup is new, all latest firmware.
M1XSP @ Address 1 is Insteon interface 2413s v1.5
M1XSP @ Address 2 is AprilAire 8811 with 6 Thermostats
M1XSP @ Address 3 is Lutron GRX-PRG interface to 7 Graphic Eye panels. This one functions simply as a pure serial interface to send TEXT commands to the GRX-PRG. For example, sending A613456^M to Port 3 selects Scene 6 on Graphic Eye panels 1,3,4,5,6.
All work fine EXCEPT - When issuing a command via rule or task to the Insteon, for example turning a Switchlink On or Off, the very next command to port 3 is dropped / ignored. The second or repeated command works fine. All subsequent commands to port 3 work fine. Only when issuing another lighting command to the Insteon(s) via the Elk lighting interface does the next command get dropped on port 3. Also, it does not happen in reverse - After sending text out port 3, the first Insteon command works fine. I also believe everything being sent to Port 2 via TStat control is fine, but am still gathering data. I have tried swapping the addresses of M1XSP 1 & 3 with same issue. This is repeatable and consistant problem.
Any advise appreciated.
Dan
Dan
