killervette
I have a dehumidifier and it has a bucket full light on it. I would like to have the elk monitor it and report when it is full. Is there a light sensor I can use on an elk zone or is there another way to do it?
You may want to consider a flood sensor, as a backup.
Sensing the level of water in the container may be another backup option.
My cheapo dehumidifier from Costco came with a threaded connector, for a garden hose, to remove water (in lieu of emptying the container). I located this basement dehumidifier next to the furnace, which has a small water 'sump' pump attached to it. There was an open knockout on the pump - I just ran a foot of garden hose from the dehumidifier to the open hole. I put the dehumidifier on an end table, for gravity drainage of the dehumidifier to the pump. The dehumidifier is firmly attached to the table with a tie-down strap, as it's heavy and we have little kids. I've never had to empty it.
I have a sump too. Does it run all the time or just when it fills with water?
My pump removes condensate from the HVAC, running intermittently. I can pour a cup of water into it, and it will run. It's a small unit, fixed to the side of the HVAC.
I am sorry for calling my condensate pump a 'sump' pump.
I now know what a sump pump is and does. I do not have one.
I have been summarily schooled.![]()
So...a condensate pump may be an option to empty the dehumidifier...
But it wasn't covered in the handouts!Haha. Test tomorrow at 8am. No cellphones.
