Elk Plug-in Connection Problems
bola09
My goal is to use the elk plug so that I can control my alarm system in Homeseer.
After the elk is configured and Homeseer is started, this is the error message that I got:
3/19/2007 12:38:28 PM - Elk-M1 - Connecting to IP 192.168.2.8:2101
3/19/2007 12:38:33 PM - COM Plugin Info - Elk-M1 Ethernet Initializing...
3/19/2007 12:38:33 PM - COM Plugin - InitIO error: Wrong protocol or connection state for the requested transaction or request
3/19/2007 12:38:33 PM - COM Plugin Erro - Error initializing Custom Interface: Wrong protocol or connection state for the requested transaction or request
3/19/2007 12:38:33 PM - Error - Initializing interface: ELK-M1->Wrong protocol or connection state for the requested transaction or request
3/19/2007 12:38:38 PM - Info - Finished initializing scripting
Subsequent to this home seer attempt to connect to Elk is capture as detail below:
3/19/2007 12:38:48 PM - Elk-M1 - Connecting to IP 192.168.2.8:2101
3/19/2007 12:38:58 PM - Elk-M1 - Connecting to IP 192.168.2.8:2101
3/19/2007 12:39:08 PM - Elk-M1 - Connecting to IP 192.168.2.8:2101
3/19/2007 12:39:18 PM - Elk-M1 - Connecting to IP 192.168.2.8:2101
My ELK PLUGIN Configuration:
Elk-M1 Configuration - 2.5.0
________________________________________
IP Address
Serial Port
Temp Probes at Zones (i.e. 1,4,7)
Number of Temp Thermostats (Max 16)
Update Temp ____ Minutes 0 = None
Update Analog Input Zones ____ SECONDS 0 = None
Arming Code (Leave Blank to Turn Off
Allow Transmit X10 to M1?
Debug Mode
Advanced Debug Mode
Auto Detect Device Additions
Activate Lutron RadioRA?
Lutron RadioRA Comm Port
Lutron RadioRA Housecode
User Configuration
1966 kola
User Name to Add
User Code to Add
Step taking thus far:
1. I have shut down both the elk board and Homeseer several times to no avail.
2. I have re-initialize elk plug-in several times, also to no avail.
Any help to get this problem solved is appreciated
I was talking to someone else about this same problem recently. Is your router set up correctly?
I use HomeSeer and the M1, but I use Electron's my.elk script to interface the two. I suggest you also post this on the HS forum for the plugin you are using. Are you using Mark's or Ultra's plugin?
Yes, it was setup correctly. I even replaced the router in case that was the problem. I should also add that I have the same set up in my house for the past four years that works flawlessly. The one giving problem is for my office. Sorry for the late reply!
Sorry for the late reply -- I use both Elkrp and, ultra's plugin. It is posted at Homeseer forum as well.
I switched to Ultra's plugin after problems with the other HS plugin. Seemed to me the other lost support, but perhaps that has changed in the last year or so. Anyway, Ultra's plugin works well for me so you may wish to give it a try.
