I posted this on the Elk BB but thought I might get some input here too>
"New to ElkRP2: expected to find here a forum for issues related to only RP2, but didn't. Anyway, I've run into several: it has crashed on occasion when entering numbers into cells for example, entry or exit delay, where the number entered (erroneously) is greater than allowed. Also, I was filling out the cut-off timers folder entries. I can change the timer values, but there appears to be no way of entering or changing the NAMES of the timers - those cells or all blue'd out. Some have names in them - numbers 8 thru 12. But that alarm, fire etc. either are unlabeled or have junk in them. I used the paper install doc to determine which timer was which. Is that normal, or should these cells be hard coded with names or better yet user editable? (ElkRP2, version 2.0.4.)"
