What are folks doing for HA control of "critical" systems in their homes?
When I got into HA about 5 years ago, I decided to put all critical control on embedded systems and moved in the direction of the Ocelot. Tied into my Caddx panel, it does what I want it to do and is very robust with lighting, IR and some basic IO control.
But lately I've been frustrated about the limitations of embedded controllers. (I know this is by design.) By limitations, I mean support for new ways of doing things. So for the Ocelot, I still have to use x10, no Insteon/zwave/upb. For IO, forget about 1-wir... Only extremely limited communication through string matching on the serial port. No ethernet....
On the PC side, I found they were too big and power hungry, complex, expensive, etc etc to do "menial" tasks such as basic x10, transmit IR, etc.
In the fall, last year I moved my entire PC HA platform to an XPe (XP embedded) system. Loaded my HA software on it and away I went. I only moved my old PC HA functions onto the "thin" XPe device. The device has been solid. Rock solid. No crashes, no issues, nothing. It's small maybe 6"x6" by a 2" high. No fans, and runs off a 12vdc supply.
Now I'm thinking about replacing my Ocelot with a similar system. XPe runs XP software, so it's possible to load apps/drivers for IR, Insteon, 1-wire, or anything else you can imagine. + The ability to add remove technologies as HA evolves. USB is there, serial is there, ethernet is there. No moving parts, solid state drives, relatively cheap.
So I'm curious as to what folks think about using embedded stable PCs instead of Ocelots Elks, HAIs.
Tim
Tim
