If you intend to use a lot of UPB, and you will be running a server 24/7 anyway, I would communicate to your UPB devices from the PC. HomeSeer has an excellent UPB plugin -- it does NOT have the problem of keeping in sync with links. If you use UPB, you WILL want to use links as it is one of the strengths of the UPB system. The plugin for HomeSeer is aware of what each UPB link activates/deactivates and adjusts all of its devices accordingly when it sees the link on the powerline.
Thanks tenholde. I've been thinking of UPB links, and since there is an inherit delay sending UPB commands, it seems links are the only way to synchronize multiple loads dimming/swittching at the same time. This is indeed a very attractive feature that I would like to keep if at all possible.
I purchased a 12-pack of the UPB 600W dimmers to get me started. My server runs 24-7 on a shared 3000VA UPS (shared w/ workstation, network equipment, etc.). It is rock solid, never crashes, and only reboots once a month for patches, and that is in the middle of the night. I don't have any concerns or problems with using a computer for HA tasks.
However - if I run the UPB from the computer....
1. How to connect the UPB to the computer? I already ordered a serial PIM -- I think that I'll be wanting to add more serial connectivity to it in the future - what are my options? (rackmount serial over IP?)
1A. I only have one serial port on the server, and it's used to talk to the UPS for safe shutdowns for low battery
1B. It's a 1U form factor, so I only have one PCI expansion slot on it (unused at the momment -- but thinking about putting an audio card in it)
2. If I run the UPB through the server, can I still expose the lights to the M1G? (i.e. Can I still use the M1G's security rules to trigger commands to the lights)
3. The UPS for my computers has a EPO connection, which from what I know is required in commercial installations. In addition to shutting everything off when someone is getting shocked, I am also under the impression that it is used by the fire department to ensure no HV power is in the house (I guess if they needed to chop through walls or something). Should I have the M1G trigger the EPO on the UPS during a fire for safety? If so, this might make me rethink my design to ensure that nothing critical is run from the computer (i.e. automatic lights to 50% during a fire is a good thing), as well as install a second smaller UPS for just VOIP-required equipment that dosn't require an EPO.
Thoughts and suggestions appriciated,
Kent
