These things are spendy. I found a couple, but I'm wondering if anyone knows of a cheaper solution. VoIP preferred, but I can do ring-down using an ATA device if needed, so analog would be fine.
http://www.vikingelectronics.com/products/...uct.php?pid=336 (Can get for around $200)
http://www.provantage.com/cyberdata-010935~7CDAT00N.htm (supports VoIP out of the box)
My plan is to replace my doorbell with this. When someone presses the button, the following happens:
- My phone switch (http://www.freeswitch.org) plays a voice prompt that says to say your name and purpose after the tone
- The switch simultaneously rings several phone numbers where I or my wife may be at, including cell phones. Caller-ID is spoofed to a number that I know is coming from the front door, and I can put it in my contact list and assign a custom ring to it on my cellphone
- When someone picks up, it says "You have a visitor at the front door: <insert recorded name/purpose here>. Press 1 to accept, press 2 to ignore, press 3 if it's a solicitor"
- If 1 is pressed, the other lines that are potentially still ringing are hung up, and the front door is patched through to the phone that pressed 1
- If 2 is pressed, it waits for the other lines to pick up and potentially press 1, or if none of them pick up, then it plays a message that says we're busy
- If 3 is pressed, it plays a message that we are not interested, and that the person is trespassing on clearly posted private property (there is a sign posted at the entrance up the road)
All I need is a weatherproof speakerphone. Or at least something that can endure an outdoor environment under an overhang and work when it's -30F. But, I really don't want to spend several hundred dollars on it. I thought about getting a "hotline" phone with no buttons, but they look dumb, and I'd be worried about the neighbor kids seeing it and wanting to play with it, or someone leaving it off hook.
