So... I have a problem with my wiring. I have three wires (two cat 6 and one 5e) running from basement, about 30-40 feet to my home office. I put ethernet plug on one end, and plug on other. I used a simple cable tester to check continuity on proper wiring of each; they are all fine. But the PCs I plug into those do not get access to the home network.
I checked to 10/100 switch (old but works) and modem/router. When i plug a laptop into both directly, it works. But when i connect the wires leading to office into them, no PC gets connection.
When I ran the wiring, i was REALLY careful not to kink wires, or run next to power.
I have another wire (slightly shorter run) that works fine in modem or switch.
Is this something that a newer, smarter switch would fix? Does anyone know why this could be happening?
I am seriously frustrated.
thanks in advance.
thanks in advance.
