Hi Guys,
Got a hair puller hope you help with.
I have a system that I have recently commissioned that today would not connect and all I get at the end of the attempt is "Failed to connect to the server"
Anyway here is the low down.
The M1 system and XEP have been working fine, was there yesterday and worked fine. I connected did some rules programming without issue. Probably connected to this system 20 times without any problem.
When I connect directly to the XEP or via the network and using the M1EXP utility from within RP2 and I can search for the XEP and can find it every time. If I try and connect to the XEP/M1 I continually get the "Failed to connect to server" message.
From the network connection I can connect to my system at home via VPN no problem at all so RP2 is OK, the network connectivity is Ok as I can see the local XEP.
Running Windows 7 on my lappy, have the lastest version of RP2 and XEP firmware.
Any thoughts? I plan on going back tomorrow and do a XEP reset and load the settings back and give that a try. Unfortunately I don't have a spare XEP to swap out to try.
Any suggestions appreciated.
Thanks and regards,
Fleetz
Thanks and regards,
Fleetz
