Four Speakers
smm6321
I'm trying to attach four speakers, (2 Elk-73 & 2 Elk M1TWS). I read other threads here that indicate that I should not drop below 4 Ohms on any combination of speakers. I measured the Ohms and get a reading of 9.5/6 if I put the meter probes between sp4 (blue) and sp1 (red). I get a reading between 6.9 and 7.4 on other combinations. Is the higher reading (9.5/6) a problem since it goes over the 8 Ohms of the speakers? I've attached a very simple diagram of how the speakers are wired using two of the black screw-type connector blocks from HomeDepot.
Spencer
4 speakers: Put two in series and the other two in series. This equals 16 ohms on each set of speakers. Place the two sets in parallel which equals 8 ohms. Down side is if one speaker blows, both speakers in series will be out.
For inside speakers the 32 ohm ELK Sp12F can be wired with 8 in parallel and only have a 4 ohm load. Loads more than 4 ohms are no problem so do not put dummy loads on the speaker lines trying to get 4 or 8 ohms.
You cannot accurately measure the impedance of a speaker with a multimeter.  Whatever reading you get will be way off from what it really is.  I can't remember the reason, but I think it has something to do with induction currents generated when the speaker is operating.
You need to go by the rating written on the speaker.
I can't speak to measurement but speakers have different impedances depending on the frequency of the audio signal.  As an example, a speaker may have a low impedance in the bass frequencies and a higher impedance at the upper frequencies.
FloridaMike said:
How did you speakers sound over 8 ohms?
What is the impedance rating of your speaker, and how many speakers are you attempting to drive?
Welcome back, DEL.
Not entirely true.
If you're trying to meter out a home stereo speaker with integral crossovers, etc. sure, but in the case of a simple driver, typically it'll be within reason or close to the listed impedance, like an 8 ohm listed speaker may meter out at 6.37 ohms...
I ended up using an 8 ohm and 32 ohm speaker in parallel. Calculated 6.4 ohms and also measured 6.4 ohms with a multimeter. Audio sounded a lot better than just the 8 ohm unit by itself leading me to believe that less ohms is better for sound quality (staying above 4 ohms of course).
For true measurement a Impedance meter is used. For general use a multimeter works just fine.
