I'm trying to attach four speakers, (2 Elk-73 & 2 Elk M1TWS).  I read other threads here that indicate that I should not drop below 4 Ohms on any combination of speakers.  I measured the Ohms and get a reading of 9.5/6 if I put the meter probes between sp4 (blue) and sp1 (red).  I get a reading between 6.9 and 7.4 on other combinations.  Is the higher reading (9.5/6) a problem since it goes over the 8 Ohms of the speakers?  I've attached a very simple diagram of how the speakers are wired using two of the black screw-type connector blocks from HomeDepot.
Spencer
			Spencer
