Ok, I put the rounded cables in last night. I think I just need to get a decoder (I was looking at TheaterTek, as well as Sage but I have to check if Sage has a decoder built in).
Regardless I should be able to show you some pictures this weekend. I put it in my equipment rack last night and it fit nicely. I had put the stealth fans in but I need to see how loud that power supply is in practice (it was intended to be a spare originally, and the other 680 watt SLI approved one I had was overkill for this box), another power supply or modifying that one to use a quieter fan might be in order.
Let's see if I can get motivated and try out the other video card configuration. I have the better card (6800 class) in the other media center, and it is a long card. While I do not have drives in the center cage I am curious to see if that card will negate the ability to put drives in that slot. If that happens, 3 slots are negated, leaving 3 drive slots on the right, and 2 optical, 1 floppy on the left. Personally I planned on possibly using the second optical as a hard drive if I populated this further (it only has a single 250gb drive at the moment).
