ddennerline
I have an Elk-M1RF2G setup. I am having some trouble with a GE NX-650 Wireless sensor (http://www.gesecurity.com/portal/GESDownload?ID=5006&DID=1893&documenttype=Data%20Sheet). It has stopped working for some unexplained reason. The sensor is installed in non-conditioned shed. This sensor has only lasted one year.
I choose this sensor because it has a rather large internal antenna, and the battery life was supposed to last 10 years. Just to verify the maximum range, I created a “non-alarm†rule and walked down the street away from my house. With a normal number of obstacles such as trees, brick walls, and two-story houses, I was able to get reliable feedback at about 300 ft.
Has anyone had problems with this particular wireless sensor failing when being used in non-conditioned space such as a shed or garage? The shed is much closer than 300ft. GE specifications indicate a temperature range of 10-120F which is never reached in my neck of the woods.
Has anyone used any other GE Crystal sensor in shed-like environment without incident?
