W wbonnell Member Jan 9, 2008 #1 Will this water sensor work with an ELK M1 married to a GE NV-548e wireless receiver?? Thanks Bill
J johndoe74 Member Jan 11, 2008 #2 wbonnell said: Will this water sensor work with an ELK M1 married to a GE NV-548e wireless receiver?? Thanks Bill Click to expand... Hi, I am not sure what is the model# for #GEWSECFS, but I have CADNX695 and it works with my ELK M1 wireless receiver. The #GEWSECFS is cheaper though, so I am also interested in knowing if this will work with M1, I could add a couple more sensors in my house.
Spanky Senior Member Jan 11, 2008 #3 You have to click the option button in the ELKRP setup to make the sensor external normally closed switch.
W wbonnell Member Feb 13, 2009 #4 Spanky said: You have to click the option button in the ELKRP setup to make the sensor external normally closed switch. Click to expand... Do you mean to check the option labeled option 1 or option 2 in the wireless setup or do you mean the "type" in the configuration under that zone??
Spanky Senior Member Feb 14, 2009 #5 Check options 1 and 2 in the transmitter setup for the water sensor to work right.
B briankelly63 Active Member Feb 14, 2009 #6 There are a variety of Liquid Detection Sensors at this site.... I use a few with the M1 system... http://www.grisk.com/security_products.htm http://www.grisk.com/specialty/2624-water-sensor.htm
