Hey everyone!  Just want to briefly introduce myself, say hi, and ask for your advice/feedback on my pending plans to wire my house.
I'm building a 2 story house + walkout basement. Approx 2800 sq ft + about 1300 in the basement (which will be finished later). I'm planning on running all of the LV cabling for immediate use, as well as futureproofing as much as possible. Right now the house is about 75% framed - so the electrian will be in in about 2 weeks to start the HV stuff, and I'll come in after with the LV.
The main goals I want to accomplish:
Some details:
Now - I'm pretty confident I can handle this task, but that doesn't mean I don't have a million questions. I've read many of the guides on here, and suggestions here and elsewhere. However, some areas are a little more foreign to me than others:
In general - I'm just looking for any additional advice/suggestions you might have to help me get off the ground and running. I appreciate all the help and the community has provided me a ton of info as I've researched in read-only mode for the past 2 months. Thanks!
- Full Structure wiring for Network and Phone
 - Distributed A/V
 - whole home audio (Nuvo Grand Concerto)
 - futureproof for home security (probably ELK?)
 - futureproof for home automation (probably ELK?)
 - futureproof for On-Q ALC Lighting (read about 36 pages of a thread on this earlier in the week
Some details:
- I have a LARGE wiring closet planned out beneath the stairs. It's actually much bigger than I could have even figured it would have been. I had one side of the stairs framed out with 2x6s so that I can have a some 4" conduits run between the basement and attic for current and future use. All LV wiring will be homerunned here.
 - I'll have access to the first floor walls from the basement, and to the second floor walls from the attic. Obviously I'll only have preliminary access to the first floor ceiling until it's finished off.
 - I have an open-source DVR product I use (mythtv). I plan on distributing the audio and the video from the closet, to eliminate A/V equipment in several of the rooms.
 - I do want to wire for whole home audio, but I will not be putting the system in until much later.
 - I want to put in security sensors now while I have the opportunity.
- Security sensor wiring - This is one area where I'm a little lost. I know there's 4 wire conductors and 2 wire conductors. I know that some sensors need the 4 wire for power, while others don't. I would assume it's probably OK just to use 4 wire everywhere to eliminate mistakes in wiring. I'm also confused with the concept of EOL resistors, and when/where they're needed.
 - Distributed HD Video - I'm a little lost on exactly what kind of Coax I should consider when distributing Component Video. I do not want to use Cat5 and Baluns for this purpose.
 - Where to purchase - I have bought boxes of Cat5 from monoprice before, but they don't stock security wire. Any favorite suppliers around here for DIY structured wiring projects?
