HA7NET compatible with all Hobby-board module & AAG weather station ?
tparvais
Hello
I'd like to know if the Bus master 1-Wire/Ethernet HA7NET is compatible with all HB sensors (including lightining, double counter, HVAC, pressure, humidity...) and also with the AAG weatherstation V3 (airvane + speed meter)
Will it provide also extra power for non parasitic mode ?
May be it's more easy to use this bus master than USB and OWFS.
Thank you
Thomas
Thomas,
If the HA7Net supports reading all 1-Wire chips then it would be compatible. I don't know about it providing external power.
Eric
It provides 200mA on each of the 3 1-wire ports.
I am using a pair of HA7Net with the hobby boards sensors for my weather station.
The HA7Net can support any 1-wire sensor. It has built in convenience features for some devices, and low level 1-wire interface for everything else.
Jayson
No. It does not provide +15VDC. I am using the HB injector for my Barometer.
this means that cabling is compatible between both systems ? (injection by injector won't cause issue on ha7net ?)
The Power Injector doesn't provide power upstream, it only provides power to devices attached to the "out" port. I don't know the HA7Net pinout but the only thing you would need to worry about is to make sure that the data and ground lines match between them.
Eric
