HAI OmniLT Programming Help.
jareds
Hi all.
I am relatively new to the home automation scene - but not very new to programming etc.
This may seem very stupid BUT I can not get the following lines to work.............
Gates - Zone.
Time1min - Flag.
"When GATES not ready:Time1min ON for 1 minute"
"When GATES not ready & IF Time1min OFF: BELL on for 1 second"
I am using an OmniLT and have been battling to figure out how to create a timer. This was the only way that I could figure it out. However, it doesnt seem to work.
When monitoring the Flag (Time1min) it works perfectly. When the Gates open, the flag starts it count down from 1 min to zero. I can not debug any further than that though.
Am I doing something wrong?
Any help will be much appreciated.
Jared
What are you trying to accomplish?
The second line will only execute after the gate opens, then closes and re-opens within 1 minute.
What is "BELL"?
If it is the alarm output, you can'control that programmatically, even though it is listed in PC Access.
I should have said what I'm trying to do hey! :)
Well, I want the siren / bell to chirp if the gate is left open for longer than a minute.
I seem so have come right though. I left that first line of code as is, but changed to the second line to:
When time1min is zero, and if gate is open, then sound the bell for 1 sec .
(Not the exact code - but that is the logic I used. )
This works. :)
Is there some example code that explains the logic for a OmniLT? There is plenty info on everything other than the LT!
