I have an omnipro ii panel and have recently aquired a couple of rc2000's.. Somewhat of a HA rookie and trying to figure some of the install out.
First, the install manual references a comm jumper. My stats dont have them. Did early versions not have the comm jumper?
Currently im just using stats asmstand alone. Looking at my panel, i see that original installer has zone 16 occupied by co2 sensor. Can stat be connected elsewhere, or odes co2 sensor need to move to another zone?
Next, i'm not sure if i can contol two heat sources from same stat? The room is primarily heated with radiant heat, but i also have an electric heater coil in my trane air handler as back up heat. The room is fairly exposed and on sub zero days, the radiant heat has trouble keeping up. Thats when i put on the coil unit to blow in some hot air. So i currently use 2 thermostats. One contolling the Trane unit for cooling and hot air and a second for radiant heat. Can i get them all on the omnistat so hot air only comes on when radiamt heat cant get t o temp? I'd even be happy with the ability to manually turn on the hot air when needed since its only used a few days per year.
And lastly, the other omnistat that i have controlling another trane ac seems to send multiple attempts to start the condenser before it succeeds. At the compressor, you can hear the switch click every 20-30 seconds for 5-6 times intIl the compressor finally starts up. Never had any problems with a generic thermostat.
Any thoughts are greatly appreciated
