programmergeek
Silly question I am trying to talk someone through programming a hai switch and I can't remember!
Anyhow if I recall you hit the switch 5 times fast to put it in set up mode. After that you should just be able to sent it a on command to program it correct? This is not working what am I doing wrong. Basically I just need to reprogram a switch to change the house code on it so it I'd not effected by his seen controller.
