HAI zwave lighting issues
sjht
I recently upgraded to the latest firmware on my OP2, installed a new VRC0P and updated PC Access. Since doing so, I have has several issues with zwave. Lights are not turning off as programmed. Example, arming the system at night usually shuts off a lot of lights, but when I get up in the morning, they are still on. The controller states they are off. Do you think this is a zwave network, VRC0P, or OP2 firmware issue? Also, can I load an old firmware back in? Thanks. SJ
I did a network repair on my zwave network (added and moved a few things recently) and the new VRC0P wouldn't update.  So, I'm going back to my previous VRC0P (old version) to see if that helps.  SJ
Just to close this.... Turns out that several associations between several nodes and deleted controllers still existed and I hit the 5 max limit when I added the new VRC0P. Had to manually delete the associations node by node. SJ
