Hauppauge HVR1600 for $59 local pickup at Circuit Citys!
CollinR
This is a combo ATSC / NTSC dual tuner for HTPC applications, it installs on the PCI bus. Although it is a "dual" tuner it is ATSC + NTSC it cannot do x2 ATSC or x2 NTSC.
Linkage
http://www.circuitcity.com/ccd/Search.do?c...archSection=All
As a bonus if you get there and they provide your part numbers:
74021
or
74041
You will get QAM functionality as well, that will live on the ATSC+QAM side, NTSC is uneffected.
Enjoy! :rolleyes:
Anyone know the specs needed for recording? It only mentions playback specs (unless they are actually the same).
recording specs are almost negligible, especially compared to playback specs. The pvr card does the encoding, so there's basically no CPU load while recording. And for digital signals, there's even less load, because of no encoding.
I have used a Pentium 550 coppermine with the side that does recording, the digital side just writes to disk.
Playback is the issue, with ATSC you are talking about a pretty decent amount of highly compressed data.
