I have just got some of my Hi-Fi 2 zones set up and upon doing some testing I have run into a bit of an issue... I can't seem to control the zones from the Omnitouch panels. I have already added all the appropriate settings in PC Access so that the console can (and does) control the sytem, and of course the local VSCs also control it fine. What happens is when I open the first audio page (to select a zone), it loads the list of zones I have programmed, and it can clearly communicate with the Hi-Fi 2 controller because all of the zones come up in the list with their associated status (volume level, on/off, source, and the values are correct and update in real-time) but when I actually click on a zone to control it, the second page either doesn't load at all, or is blank (no buttons other than main menu panel).
I have added all the button images for the Hi-Fi 2 in AS and at first when I noticed this problem the first thing I did was re-import the Audio and Audio 2 pages from the 5.7e template design in AS but it did not resolve the problem.
Is there more of a specific process I can refer to in terms of adding the Hi-Fi 2 to AS? I have looked around everywhere but there doesn't seem to be any documentation on it.
I've attached a photo of what the audio2 page currently looks like in AS, which is about what it looks like on the touch screen as well lol. Should the buttons be visible in AS? When I open the sub-panel it is also blank inside.
Thanks in advance for any help on this.
Ryan
Ryan
