I have a few questions regarding wiring for home automation center to audio:
1.) The connection from the HAI Omni PROII to NUVO is RS232. Tech suprot at NUVO suggests that this be a short run. After looking, I’ve read its good to at least 50’ and someplaces say 100’ (http://www.rs485.com/rs485spec.html) . But tech support thinks is should be shorter. One solution I read about and would like his advice ont is the other possibility of to converting it to some other long distance protocal (I need 50’ at most) and back again to RS 232. For example: Cat5, RS422 or R485 can be easily converted using converts: http://www.bb-elec.com/SubCategory.asp?SubCategoryId=11. Will this work? And what kind of cable should I run (its in the walls, so I have to add the connectors later)
2.) Will CD players able to be controlled and have the CD info viewed using the HAI omnipro II through the console if its hooked up through the Nuvo E? Or are there special CD players that work well with these systems together?
