123
Is there a way to programmatically trigger a Fire, Medical, or Police alarm (for an ELK M1)?
The M1's ASCII Protocol allows you to arm/disarm it programmatically (using commands "a0", "a1", "a2", etc) but I can't find a similar command to trigger a Fire/Medical/Police alarm. The only solution, and it a flimsy one, is to issue a Keypress command ("kf") to trigger a keypad's Function Key 1, 2, or 3.
It is hardly a robust solution because you're relying on the keypad's function keys programmed to be F1=Fire, F2=Medical, and F3=Police. However, you're out of luck if F1 is programmed to open the garage door! Unfortunately, there's no way to determine a function key's programming.
Anyone know how to do this reliably?
PS
My band-aid solution is to provide a keypad property called "Emergency". If the user enables this flag it tells me the keypad's first three function keys are programmed as Fire/Medical/Police. I can then use the "Emergency" keypad's function keys to trigger Fire, Medical, and Police alarms. The user would have to define at least one "Emergency" keypad per Area.
PS
