SpaceCowboy
Is anyone using any humidity sensors out there with their Elk M1G panel or a communicating themostat? Can you describe what you're using?
I'm planning on using a RCS TR40 thermostat with my M1G panel. I was thinking it would be great toh ave some humidity sensors around to help trigger some events.
Example: When it gets cold here in Calgary (as I'm sure it does elsewhere too) I need to lower the humidity in the house so as to not ice up the inside of the windows.
I was also thinking about sensing the humidity in the bathroom after a shower and letting the fan run until the humidity dropped below a certain threshold.
Is anyone doing something like this? I don't see native support for humidity in the RCS products but figured I should be able to add a sensor to the M1G. Wireless might be great but also seems to cost $$.
Thanks for all the great advice and help. This place is great for ideas!
