here is my situation
i currently have a heat pump hvac with a non-electronic thermostats. i would like to gain control of the temperature by zone in the house (4-6 zone). i would use normally opened damper to split the zone. i'm on a limited budget ( 500- 800$)
so here is my question
-what system/controller should i use? ( a thermostat with multiple sensor would be nice)( i have acces to a computer that could be used as a "server" to control everything)
- what are the easiest temp sensor to work with using that system?
i would like to have only one thermostat ( or only computer controlled with one in the hvac room that could bypass the system in case of it failing)
i would like to be able to acces the system for future home automation upgrade( web acces/phone acces, data logging of the temperature ...)
the system has to be able to control the heat pump and the electric furnace for heating and cooling, and control the damper
thanks for your help
