Can someone help me convert my DS2450 voltage reading to a 12VDC equivalent. I want to monitor a 12V battery in order to turn on a battery charger when the voltage drops below 12.4VDC I have used 2 equations Vb = (Vs * 10) +1 and Vb = (Vs * 11) _0.715 (Vb = battery volts, Vs = DS2450 volt.A, 2nd equation from OWFS). Neither of these is close enough to monitor my battery. The measured voltage at the input connector is 13.9VDC and the voltage from the DS2450 is 1.09697 which converts to 11.97 and 12.07 VDC. I am not sure whether to adjust the multiplier, the added amount or both. Thanks William
