sure, of course it is behind my firewall. and since it is, I'm not really needing any additional unnecessary embedded security measures, like making it impossible to change things remotely, from within my secure lan :mellow:
but, I'll live with it and won't make a feature request. I have my own php interface for interacting with the data, and I can send some stuff back to the wc8 with buttons, like the uroms or ttls. but what would be extremely nice is to be able to change some of the timings I use in the plc, for controlling valves and whatever, or any of the other triggers, from the convenience of my own php interface. even if I have to reload the entire code for any change, which it seems would be the case.
I might be able to code for a set of different timings and select which one I want by sending bits to the ttl inputs, but that is a little limited. reaching into the heart of the beast and editing its code from my own control panel widgets would be much preferred to having to use the onboard web interface. particularly if I wanted to develop an interface for a client to use. seems like an api for this wouldn't be too difficult, you could do it, if you wanted to
In slightly related news, I have the MCP23017 working, it was easy, took about half an hour. opens up potentially 128 additional ttls. I'm adding an additional 16 outputs for relays, and as many as I can for inputs, from our security system, primarily a lot of motion IR sensors, a few capacitive proximity, and some light beams. for these things I don't really need to capture the data, but I have that working too, buffering the bytes out thru the VARs. the sixteen 16 bit analog values from the four ADS1115s can also fit out thru the eight 32 bit VARs, two in each, MSB and LSB, then rehexed and split by my script and saved in sqlite. all working, stuff I did while waiting
having sixteen 32 bit VARs in the wc32 will allow moving out twice the data per cycle. I notice there is a serial port on that board, but I do not see any plc syntax in the guide for using it. Is it hiding somewhere in the examples?
