I'm trying to wire a deadbolt sensor on my front door. My house is three stories and I'm getting quite sick of thinking "Did I lock the front door?" when I get to bed and then going down and then back up two flights of stairs just to check it. In my old house I had simply installed two little metal tabs on the top and bottom of the deadbolt hole (I don't even remember what I used for them... some bit of sheet metal I had laying around) and connected the wires right to the tabs... when the deadbolt was closed it closed the circuit and when it was open it opened the circuit... that worked (for the most part... it was maybe 95% accurate... occasionally the deadbolt didn't make contact and it read as open even when it was closed). I'm thinking of trying to find another solution for this house, but that's not the biggest problem I'm having.
The biggest problem is trying to run a wire to the deadbolt... you can see what my front door looks like if I managed to upload the image properly
The problem is that there are windows on all three sides of the door. The house is on a slab, so there is no basement to run wires through.
It would be pretty easy to put something in the deadbolt hole and run the wire under the weather stripping around the door. While probably not ideal I think that's about the only way I'll get the wire to the top or bottom of the doorframe as it's solid wood between the door and the window. Unfortunately, once it gets to the top or bottom of the doorframe I'm not sure where to go from there.
Here are my curent thoughts along with some of the downsides...
The door has a recessed magnetic contact on the top that's connected to the alarm system. I thought about trying to tie my deadbolt sensor into that and just wire it in series with the magnetic sensor. Assuming I could get the recessed contact out and that the wires are long enough to work with then it would be pretty easy as far as the wireing goes... it could all be done behind the weather stripping. However, I'd have to get a much more reliable way of detecting the deadbolt. The 95% accuracy I got on my old house was fine when all it meant is that I had to get out of bed to check the door when it was wrong... but now with it connected to a monitored alarm it could mean waking up at 3AM when the alarm starts going off and having the police dispatched to my house. Additionally I would lose the ability to tell if the front door is actually open or just unlocked. Given that there is no screen door and I have indoor only cats I like the ability to make an announcement if that door is left open for more than a minute or two.
I also considered using a DS10a, but I don't like having it exposed and there isn't a great place to hide it. I initially thought about going up and putting it below the window that's above the door, however that ledge is visable when you're coming down the stairs. The other thought I had was to run the wire down to the bottom of the doorframe (through the weather stripping) and hiding the DS10a under the window on the right of the door behind the brown curtain. The other downside to the whole DS10a thing is that I don't currently have a DS10a or a receiver for it (the MR26A doesn't work with the DS10a's, does it?). I can get them, however, that increases the cost of this project significantly.
Finally, if I can get a wire through the half wall into the room on the right side of the picture, then I can run it under the baseboard halfway around the room and then through another wall into the closet where my homeseer computer is. I think this might be the best solution as it would be invisible, seperate from the alarm system, and inexpensive, however, I just can't figure out how to get the wire under the baseboard in the other room without making a lot of holes in the drywall in the foyer.
Do you guys see anything I'm missing or have any other thoughts for me?
Thanks much,
Brett
Thanks much,
Brett
