Thanks Damage.
I'm at a brick wall right now. All I have are 16Gb microSD's. Here are the steps and my predicament (think I'll order smaller 8Gb microsd's). Think the mistake was to originally load tool-chain on the source microsd - for a while copies did work though - now kind of mangled.
1 - DD'd original 2Gb microSD (after I installed toolchain on it)
2 - DD'd it to 16Gb microSD - used GParted to expand partitions 2,3,4 (made partitions 2 and 3 the same).
4 - expanded partition 4 such that it occupied rest of microSD (5-6 Gb).
5 - this completed microSD boots fine but GCC doesn't run on it. (but I can see it there).
6 - re-ran install for GCC - downloads and gets about 3/4 done and then it starts to error out not finding subdirectories.
7 - Read somewhere (related to Chumby 1 - not sure if its the same with Infocast) that partition 4 is actually an extended partition with two subpartitions on it (5 and 6) - I didn't know this earlier.
8 - tried the restoral from USB (holding the touchscreen and prompts) and for whatever reason it starts to read the memory stick and quits after about 20% (tried various memory sticks).
9 - I have another unopened Chumby and I guess I could image that microSD and start from scratch with that one instead of the image that I have been using.
Current image on the 16Gb Infocast though is working except for the problems listed above. I know I'm making more of this than necessary and more complicated than it really is.
Did you use the same size 2Gb microSD or did you go to a differently sized microSD?
