Integrated Camera and PIR question...
Timoh
What do folks think of the Vitek VT-PIRB2 PIR-Camera combo?
http://www.automatedoutlet.com/product.php...=101&page=1
Is the extra $50 worth it for colour? I noticed that the B&W white also offers higher resolution.
It will be an indoor setup.
My other issue is I only have 2 pairs going to the location... Not cat5. A balun is required, but I don't have enough pairs if I use balun.
Gnd
+12
Video
PIR trip (relay, wired into 12v supply) will drive a local local relay or transistor closer to panel.
But if I use a balun I need 2 wires (1 pair for balanced video), which only leave 1 pair to power the unit. No room left for PIR on the wire. If I don't use a balun, I'm presuming that my distance will be severely limited before I start losing quality.
Any ideas?
I have thought about driving the camera into a PC and using motion detection software to detect movement. Then feed the motion detection into my HA which would trigger a relay wired into my panel zone. I'm trying to leave my PC out of my security setup. i.e. If my PC fails, no more motion detection!
Tim
bump
Anyone? PIR and video over 2-pairs (4 conductor) wire? Less concerned about thoughts on the product.
Tim
If you really need 2 pair for video (I think I tried it successfully with 1 pair and a balun too tho), you could use one of those X10/Insteon/UPB I/O modules that translates contact closures to powerline. You might even be able to use a DS10A window/door sensor if you have the W800RF32.
I have the color version, that's what's in the top-right shot here, but I ran RG6 so I don't know about your wiring question.
