Will give this a try in the morning. Thanks!
EDIT: well, OK, I just could not wait. I just loaded it up and it ran perfectly!! See output:
23:42:37.341 INFO
Important:
Configuration is now read from your pool. The application will send the commands to retrieve the custom names and circuit names.
It will dynamically load as the information is parsed.
Visit http://_your_machine_name_:3000 to see a basic UI
Visit http://_your_machine_name_:3000/debug.html for a way to listen for specific messages
23:42:43.002 VERBOSE Express Server listening at port 3000
23:42:43.040 VERBOSE Serial Port opened
23:42:47.942 INFO IntellicomII Controller Detected. No configuration request messages sent.
23:42:47.956 VERBOSE Msg# 1 Main --> Pump1: @ Pump Timer 1 : minutes [96,16,1,4,3,43,0,1,1,73]
23:42:47.975 VERBOSE Msg# 2 Pump1: Speed Set to 1 rpm: [16,96,1,2,0,1,1,25]
23:42:48.034 VERBOSE Msg# 3 Main --> Pump1: @ Save Program 1 as 750 : rpm [96,16,1,4,3,39,2,238,2,52]
23:42:48.053 VERBOSE Msg# 4 Pump1: Speed Set to 750 rpm: [16,96,1,2,2,238,2,8]
23:42:48.134 VERBOSE Msg# 5 Main --> Pump1: @ Save Program 2 as 1740 : rpm [96,16,1,4,3,40,6,204,2,23]
23:42:48.153 VERBOSE Msg# 6 Pump1: Speed Set to 1740 rpm: [16,96,1,2,6,204,1,234]
23:42:48.232 VERBOSE Msg# 7 Main --> Pump1: @ Save Program 3 as 2000 : rpm [96,16,1,4,3,41,7,208,2,29]
23:42:48.253 VERBOSE Msg# 8 Pump1: Speed Set to 2000 rpm: [16,96,1,2,7,208,1,239]
23:42:48.329 VERBOSE Msg# 9 Main --> Pump1: @ Program 4 as 3250 : rpm [96,16,1,4,3,42,12,178,2,5]
23:42:48.351 VERBOSE Msg# 10 Pump1: Speed Set to 3250 rpm: [16,96,1,2,12,178,1,214]
23:42:48.430 VERBOSE Msg# 11 Main --> Pump1: Remote control (turn off pump control panel): [96,16,4,1,255,2,25]
23:42:48.452 VERBOSE Msg# 12 Pump1: In remote control: [16,96,4,1,255,2,25]
23:42:48.532 VERBOSE Msg# 13 Main --> Pump1: Pump power to off: [96,16,6,1,4,1,32]
23:42:48.554 VERBOSE Msg# 14 Pump1: Pump power off: [16,96,6,1,4,1,32]
23:42:56.850 VERBOSE Msg# 15 Main --> Pump1: @ Save Program 1 as : rpm [96,16,1,4,3,33,0,0,1,62]
23:42:56.874 VERBOSE Msg# 16 Pump1: Speed Set to 0 rpm: [16,96,1,2,0,0,1,24]
23:42:56.917 VERBOSE Msg# 17 Main --> Pump1: @ Pump Timer 1 : minutes [96,16,1,4,3,43,0,1,1,73]
23:42:57.462 VERBOSE Msg# 18 Pump1: Speed Set to 1 rpm: [16,96,1,2,0,1,1,25]
23:42:57.996 VERBOSE Msg# 19 Main --> Pump1: @ Save Program 1 as 750 : rpm [96,16,1,4,3,39,2,238,2,52]
23:42:58.013 VERBOSE Msg# 20 Pump1: Speed Set to 750 rpm: [16,96,1,2,2,238,2,8]
23:42:58.050 VERBOSE Msg# 21 Main --> Pump1: @ Save Program 2 as 1740 : rpm [96,16,1,4,3,40,6,204,2,23]
23:42:58.073 VERBOSE Msg# 22 Pump1: Speed Set to 1740 rpm: [16,96,1,2,6,204,1,234]
23:42:58.149 VERBOSE Msg# 23 Main --> Pump1: @ Save Program 3 as 2000 : rpm [96,16,1,4,3,41,7,208,2,29]
23:42:58.173 VERBOSE Msg# 24 Pump1: Speed Set to 2000 rpm: [16,96,1,2,7,208,1,239]
23:42:58.249 VERBOSE Msg# 25 Main --> Pump1: @ Program 4 as 3250 : rpm [96,16,1,4,3,42,12,178,2,5]
23:42:58.273 VERBOSE Msg# 26 Pump1: Speed Set to 3250 rpm: [16,96,1,2,12,178,1,214]
23:42:58.347 VERBOSE Msg# 27 Main --> Pump1: Remote control (turn off pump control panel): [96,16,4,1,255,2,25]
23:42:58.371 VERBOSE Msg# 28 Pump1: In remote control: [16,96,4,1,255,2,25]
23:42:58.446 VERBOSE Msg# 29 Main --> Pump1: Pump power to off: [96,16,6,1,4,1,32]
23:42:58.501 VERBOSE Msg# 30 Pump1: Pump power off: [16,96,6,1,4,1,32]
23:42:58.549 VERBOSE Msg# 31 Main --> Pump1: @ Save Program 1 as : rpm [96,16,1,4,3,33,0,0,1,62]
23:42:58.573 VERBOSE Msg# 32 Pump1: Speed Set to 0 rpm: [16,96,1,2,0,0,1,24]
23:43:07.953 VERBOSE Msg# 33 Main --> Pump1: @ Pump Timer 1 : minutes [96,16,1,4,3,43,0,1,1,73]
23:43:07.972 VERBOSE Msg# 34 Pump1: Speed Set to 1 rpm: [16,96,1,2,0,1,1,25]
23:43:08.027 VERBOSE Msg# 35 Main --> Pump1: @ Save Program 1 as 750 : rpm [96,16,1,4,3,39,2,238,2,52]
23:43:08.053 VERBOSE Msg# 36 Pump1: Speed Set to 750 rpm: [16,96,1,2,2,238,2,8]
23:43:08.127 VERBOSE Msg# 37 Main --> Pump1: @ Save Program 2 as 1740 : rpm [96,16,1,4,3,40,6,204,2,23]
23:43:08.153 VERBOSE Msg# 38 Pump1: Speed Set to 1740 rpm: [16,96,1,2,6,204,1,234]
23:43:08.227 VERBOSE Msg# 39 Main --> Pump1: @ Save Program 3 as 2000 : rpm [96,16,1,4,3,41,7,208,2,29]
23:43:08.253 VERBOSE Msg# 40 Pump1: Speed Set to 2000 rpm: [16,96,1,2,7,208,1,239]
23:43:08.326 VERBOSE Msg# 41 Main --> Pump1: @ Program 4 as 3250 : rpm [96,16,1,4,3,42,12,178,2,5]
23:43:08.352 VERBOSE Msg# 42 Pump1: Speed Set to 3250 rpm: [16,96,1,2,12,178,1,214]
23:43:08.422 VERBOSE Msg# 43 Main --> Pump1: Remote control (turn off pump control panel): [96,16,4,1,255,2,25]
23:43:08.451 VERBOSE Msg# 44 Pump1: In remote control: [16,96,4,1,255,2,25]
23:43:08.523 VERBOSE Msg# 45 Main --> Pump1: Pump power to off: [96,16,6,1,4,1,32]
23:43:08.552 VERBOSE Msg# 46 Pump1: Pump power off: [16,96,6,1,4,1,32]
23:43:08.627 VERBOSE Msg# 47 Main --> Pump1: @ Save Program 1 as : rpm [96,16,1,4,3,33,0,0,1,62]
23:43:08.653 VERBOSE Msg# 48 Pump1: Speed Set to 0 rpm: [16,96,1,2,0,0,1,24]
EDIT: I did see that this line needed modifying:
<3><33> is the command to select the pump speed program to use. <0> for off, <8> for speed 1, etc.
