Haiku Introducing the HaikuHelper jQuery Library
lupinglade
We've just submitted HaikuHelper 2.50 to the App Store and amongst many other improvements, we have added a jQuery Library for you to use when creating custom Interfaces using HaikuHelper. With this new library you will not need to worry about retrieving, adding, updating or removing objects on your Web Interface. The library takes care of all of this for you with just a few simple calls and maintains your lists, etc -- updating instantly as changes happen in HaikuHelper or on the controller. We've updated the Default Interface to use this new library as well as a new Buttons 2.0 example for you to see just how easy it is now to create amazing Interfaces using HaikuHelper. We're also working on more sample Interfaces that we will share with you soon. The documentation link on this forum has been updated to include documentation for the new library, which is very easy to use and is extremely versatile, allowing very customizable user experiences that will rival any top notch interface.
Attached is a pic of one of the new Interfaces we're working on. You can't see it from the picture, but the UI is fluid and when you point to any of the items they rotate in 3D and let you adjust each item. The effort now all goes into the graphical and UI design, hardly any JavaScript code is needed to make it all work!
[sharedmedia=gallery:images:490]
