By this I assume you mean CQC driver doesnt support the active notication in RZCOP?
I found a deal on some homesetting switches, $25 a pop so makes me rethink how much I need the active notification?   My goals are:
* control outside lights, to start I would just turn them on/off at night, phase II would be to control via  a motion sensor linked to alarm.  I really like to know if someone is walking up side of house at anyway so I figured a motion sensor tied to alarm tied to CQC is the way to go.  Once I might as well tie that to the lights rather then using a 'dumb' motion sensor
* turn off some key lights  and outlets when the alarm is armed(no one home)
* turn on/off some lights in living and master bedroom via remote via IRA2 via CQC.
* shut garage work area lights off when no one is in there or based on a timer.
In what cases do I really lose without the active notification?
I think you do something where someone enters a room, turns on a switch and motion sensor checks for motion in room and turns off light once no one is present.  I could see this working smoother if you had active notification.
Is there a big draw on the system polling devices?  If I get to 30 devices it would be a lot does that put a big drain on the network if you poll each of them once a minute?
			yes, no polling needed like with homesettings.
I only used the ViziaRF for a short time with CQC. It doesn't have polling, so as of this moment my RZCOP is just sitting there doing nothing.
