Is there a sip doorphone that has two relays?
I want to be able to trigger an event when the door bell is pressed, as well as be able to use the doorbell to buzz the door open.
You want a doorphone that is SIP and gives you outputs....you need to use their products and integrate on some level. What level depends on what you put in.
I just checked that one out. The problem is like the cyberdata, it only has one relay. So I can either have it cause an alert when the button is pressed, or I can use it to buzz a door open. I cant do both.
The RC-4 sounds like it'll do what you're looking to do
Then again, there's no mention of what you have or what you're trying to do with what hardware.
Is there a reason why something like an Aiphone integrated with whatever piece of hardware is downstream? The Aiphone can do multiple relays and has multiple inputs. The Viking has 4/4 and an IP interface.
Easy enough to put an E-30 and then drive it to an RC-4 and do whatever you need to do on the back end.
I have an asterisk system at home running my phones so I want to tie it into the same system.
The reason why I want two relays is:
One relay to hook up to my ELK M1, to cause the system to get my camera to take a picture and email it. And the other relay to be used as a buzzer to open the strike if I type in a code while on the phone with them.
