That's the way I always cleared the lines: One connection where I attached the compressor, and cycle the zones while the compressor is running. Let each zone run until all the water is evacuated. Before you remove the connection, make sure you turn off the water supply to the system. Plus, if you have outdoor hose spigots, keep in mind some of those may be tapped off the sprinkler system, especially if they're located away from the house. If so, you must open those spigots and let the compressor clear those lines, too.At the supply end of the irrigation system, there is a fitting for the compressor, which allows one to hook up the compressor and just run the irrigation system through all of the zones.
I guess I could get an adapter for a leaf blower, but I don't own a leaf blower.
Kevin
