wkearney99 said:
The most important thing with windows is don't drill holes in a way that's going to degrade their ability to keep the water out. All too often some half-assed installer (or whomever) does something dumb like drills up through the bottom at a point where water collects and that drips into the wall. Eventually rotting everything. A well designed window has a plan for managing water. They're designed to collect it and get it away. Put holes in the wrong place and you risk disrupting that design.
This is excellent advice. I will find out from the manufacture the best way to handle this. I'd prefer embedding switches in the jam to be totally invisible, however surface mount switches might be smarter for the reasons mentioned.
My thought was to mount the switch in the jam with 2 small rare earth magnets on the window itself. One for the closed position and one 3" above it to allow the window to be cracked and armed.
Our CG doesn't like Pella. Something about overpriced and some other thing I don't remember that he didn't like. He's used Lincoln windows for a while. 20 year warranty and seem well made.
We had Anderson windows in previous house. They were okay, but not special. It was also many years ago and I'm sure there are improved designs.
In our current house, we've replaced 1/2 of all the windows after 5 years of age because of leaks (fogging). So I'm hoping 20 year warranty will prove better seals.
Going back to my original question, wires in the windows poses sheetrocker challenges. I'm imagining my wires in the window jam and a roto tool buzzing alongside cutting right through.
Pete, did you terminate switches on windows before or after sheetrock? I guess surface mount switches, you could pull the wire alongside the window and hope they don't slice it.
Never having done this, I'm trying to learn how this all works.
--Russ
