Elk M1 system in a residential home installation. For motions and glassbreaks do I need to set the outputs for latching these inputs will be going to an XIN expander card.
Next question if I setup the garage for overhead door switches, 2 motions in garage and a contact on the door from the garage into the home what is the best way to setup the definitions and have security in there while a family member has yet to arrive home via the garage in the evening. The M1 will know when the remote is opening the garage door via the M1XRF2G from a keyfob input. There will also be a weigand reader in the house after entering thru the entry door via the garage.
On the above Im looking at the definitions available Im thinking as follows let me know what you think:
Overhead doors Def 02 for more time delay
Garage entry door Def 01 for standard time delay
Garage motions Def 07 for burg interior nite delay ? This I guess is a secondary to the garage door overhead contacts which are of higher security setting at def 02 when in the stay or stay instant modes.
Is this a good approach as I would rather not disarm with the 4 button crystal keyfob and use the weigand keyfob to disarm upon entry into the home.............Or on second thought when the last family member comes home at night thru the garage can Elk be setup to recognize this in the rules and instead of disarming can it go into nite or nite instant mode?
Thanks in advance for the input on these questions.
