Neurorad
Thanks for the tip!I would get a night light it will still draw less just because you are at 20% you are usally still buring 60% power. Get a 1w led off amazon for $10. and hook it up much better way to go.
So last night on my way home, I stopped at Home Despot and picked up a Philips AmbientLED PAR30 bulb to test out in my kitchen. It's 11W, 418 Lumens, 3000K.
I put it in one of the 6" recessed cans in my kitchen, replacing a Ushio 75W PAR30 rated at 1100 Lumens.
I think at this point the CREE LR6 is the can light replacement to beat. Its in every way as bright as the 75W lights its tries to replace and it draws a total of 9W by my measurements. Its semi-dimmable. Goes to about 30% without a problem, but if you want 5%, like was said, you better off adding a second light to perform that function.
The PAR38 version of the bulb I got puts out 600 Lumens, the same as the Cree bulb.
Does the Cree give you a "cone" of light, or is it heavily diffused?
I'll say it again... to this date, the Cree LR6 is the best recessed retrofit bulb I have seen.
I have both the bulbs and the stock and both have been pretty impressive.
And while the LR6 is pretty incredible, the ones they are testing now are really incredible, approaching 100 Lumens per watt. Walmart must be impressed as well. They are replacing their ceiling lighting with Cree lights in 650 stores. The Cree bulbs not only last longer, but they are claimed to be 82% more efficient than the metal halide bulbs they replace.
I wish someone would release one based on the SSC-P7 LED. A single LED puts out 900 lumens. I have a flashlight that uses one, and it's insanity. Easily 10 times brighter than a 3D Maglite. If you shine it down on a concrete floor or other light colored floor, it's too bright to even look at the floor. Mine has a wide fixed spread on it, and I can still light up houses 1/4 mile away. Uses rechargable Li-ion batteries. Color temp is about 6500K though, which is way too white for interior lighting, it would have to be mixed with red and yellow LEDs to bring it down to 2700-3100K.
Check out the LED stuff on http://www.dealextreme.com There is some great stuff there for dirt cheap. It just takes like 3 weeks to get it from Hong Kong. They have some Cree based PAR bulbs with an edison base, but no info on the color temps or lumens.
What is the brand name of your flashlight? I'd like a super bright light.
Matt
Speaking of LED bulbs, does anyone know of any affordable under-cabinet LED lights? Every light bar that I've seen has been over $200 each and I find that a little steep. I bet they only cost 10 or 15% of that to manufacture.
Maybe I should just buy some high-intensity LED bulbs and wire up my own in some sort of aesthetically pleasing housing...
I bought a bar of these to test with from DealExtreme. It cost me about $8. Item# 5256
It's bright, but probably around 6000K or so for color. Too blue for under cabinet lighting, but might be good for a workbench area. They have some other ones available also that might be different colors.
