miamicanes
I'm going to be using Pass & Seymour jumbo unbreakable Decora-style light-almond outlets and faceplates in my newly-remodeled living room. HOWEVER, I'm stuck with one of the switches, which needs to be a "double decora" style switch (two switches with the formfactor of a single decora paddle). I already have Leviton double & triple-decora switches in multiple other places in the house. Leviton's flip from side to side. Pass & Seymour's flip up and down. I'd like to keep the living room consistent with the other rooms and use Leviton's switches there, too. Mixing WHITE Leviton switches and P&S jumbo unbreakable wallplates was no big deal, because "white is white". But I'm agonizing over whether Almond (Leviton) and Light almond (P&S) are close enough to get away with.
I feel really insecure about it, because I'm technically colorblind. I'm mildly trichromanomalous... I see RGB, but my red-peak is shifted towards my green peak compared to "99% norm", so I can't reliably tell the difference between subtly-different pastel shades. In computer terms, if normal vision has 8 bits for red, green, and blue, my red perception only has 7 bits. What's weird is that I actually didn't even KNOW until about 5 years ago when I had laser surgery... as part of the pre-op testing, the doctor had me take a test where you're shown a yellow laser and have to match it by adjusting the intensity of red and green lasers, then had me do the Munsell color-matching test... both of which I consistently failed. In a less technologically-sophisticated era, I would have just been written off as having bad taste in colors. Now, I know it's not my fault, and that I just have messed up reference points. But it makes picking paint in neutral grayish shades an absolute nightmare, because I could put ever-so-slightly pinkish-cream trim next to ever-so-slightly greenish-yellow beige and never know anything is wrong.
Anyway, getting back to the original point... are the two shades of almond close enough to get away with mixing Leviton switches with P&S plates? Are they IDENTICAL enough to get away with going a step further, and putting a P&S single paddle switch right next to a Leviton double-decora switch?
