ddennerline
My VRUSB+3 stick got cranked backwards and USB connector separated from board. You have to very careful walking around the house so you don’t jab the VRUSB against a door as it sticks out 3 inches.
I ordered a new stick. It appears that Leviton has changed VRUSB+3. The exterior is different, the light is green, and light is recessed. I don’t know if firmware interior has changed.
This USB stick will only work with Leviton Installer Toolkit 1.1.1.0. Versions older than this will not recognize the USB stick.
This version of the toolkit crashes quite frequently. Apparently, Leviton knows about this issue. They have been less then helpful with all my requests. Basically my lighting network is not working correctly due to instability.
Second, Leviton has deleted the VRUSB+3 19 virtual buttons, so you cannot assign specific “areas” to specific button identifiers. If you attempt their CNTL+SHIFT+B workaround, a crash ensues. Without the 19 virtual buttons figuring out the GroupID to enter into ElkRP is difficult. Basically group synchronization functionality in VRC0P+3 is broken too. Whenever I try to execute a group command from M1XSLZW, all my lights in house turn on/off. I know that secondary controller synchronization must be working at some level because the same area can be correctly controlled from a 4-button scene controller.
Lastly, my locks now refuse to be manipulated by VRC0P+3. They enroll correctly. HyperTerminal will not communicate with them. About the only RFITv1.1.1.0 improvement I can see is that locks can now be locked/unlocked from device screen. The odd thing with Kwikset locks can be manipulated using new lock/unlock button from RFITv1.1.1.0. Locking was working correctly with older RFIT and VRUSB+3.
Has anybody else had similar experience if they rebuilt network using latest versions of RFIT and VRUSB+3?
Several times Leviton phone technicians said they would call me back, and I no callback/status update is returned - very disappointing. It's not like a bought a $100 router. Basically, I have a non-working multi-thousand dollar lighting system.
