The VRCZ4-1LX is a 4 button controller but will not control a load.
So does it need its own box in the wall with power to operate, since i cant take out an existing switch and replace that switch with it?
Could I use it in a 3 way application, where by a put a levtion dimmer/switch in one of the two 3-way switchs, then install the 4 button in the second of the 3-way switch locations and leave the traveler wire capped and disconnected at each end?
