Hi,
I have voicemail supplied by my telephone provider, so the only way around it if I want remote tel access is to use the Ring/Hangup/Answer option (G29 / G30). My telco's vmail currently picks up after 4 rings. I have set G29 to 5, and G30 to Yes.
Under normal conditions, when calling locally, everything works as expected. If the phone rings 4 times, vmail picks up. If I call, hangup and then call back, the M1G picks up. So far so good.
My problem is the following. Long distance calls have a different ring; they ring in 3 short rings cycles. ie: Ring, ring, ring. Pause. Ring, ring, ring. Pause. etc... So when I get a long distance call, the M1G mistakenly interprets the first three short rings as 2+ rings and starts the 45 second counter during the pause. When the second ring cycle starts up, the Elk automatically picks up. Which means that unless I am fast and answer a long distance call before the 2nd cycle, the M1G always picks up my long distance calls!
Although that's great to handle telemarketers, it sucks when you have family calling.
Is there anything I can do to prevent this, while maintaining remote telephone access? Is there anyway I can modify the amount of time required to wait before the 45second counter starts? Or any other solution I can use?
Thanks!
Eric
Thanks!
Eric
