OMG! I just typed a ton of stuff and my stupid accidental gesture lost it all.
So - here's my summary! 1st - trash or return that amazon cable. It's garbage. Unshielded copper-clad aluminum - no thanks... not for any job ever. I wouldn't even run that indoors only. If you end up needing burial grade Cat5 then go with something better that's shielded, reputable, and not copper-clad aluminum. I use a lot of
Ubiquiti ToughCable - it's great because it's not gel filled and can handle burial, UV exposure, etc... that said, as long as you're not doing much vertical run then
gel filled can be good too - if not better. However, with CatX (5/6) cabling in an exterior environment, you also need shielding. I use polyphaser a lot especially when doing high-dollar jobs - it has served me well. And even though you'll be in conduit, that's really merely a convenience factor (albeit a huge one!)... you still have to run outdoor burial rated cable because inevitably conduit is/becomes a wet location and must be treated as such.
Also I'd run the biggest conduit you can - the traditional gray PVC you see in the box stores at the electrical isle with the correct ends/housing to enter the structures. I'd also have the electrician run a solid ground right where the conduit enters the building so you have a way to ground/drain anything that passes between structures.
Continuing on - you have a couple things going on here. Running CatX cable between structures isn't as easy as it sounds. Done right you should be compensating for surge protection. I don't know your climate/region but that may be more or less of a concern. Luckily where I'm at it's hardly a factor but for most of the US it's huge, and I still account for it in order to provide lasting quality installs. Instead of running multiple CatX cables to home run your cameras and other items, you'd be better off running 1 and using a switch in the garage. You can protect that cable with surge protection - or better yet, you can use pre-terminated fiber cables to length, and use something like a
Netgear GS110TP switch with the fiber transceivers to make yourself 100% immune to static/surge and make life unbelievably simple... I'm a big fan of that switch because it supports VLANs, it's POE, etc - I've probably bought 30+ in the last few years.
For the security, there's opportunity for betterment there as well. Instead of trying to run multiple conductors which are surge and power susceptible, what I'd do is similar to what I did in my own home... The M1G uses an addressable system in which many key devices may be located remotely. In my install, instead of running multiple sensors back to the primary panel, I chose to install a sub-panel in the garage. This is served by a single Cat5 and can be powered by a P212s which has the added benefit of powering/charging a battery in the remote structure. Once you have the databus in the garage, then you can control keypads, inputs, outputs, etc.
